Old 09-05-2014, 10:40 AM   #1
Reebuck1
Reebuck1
I found it!
This is the same DME 88 pin plug used on the early 996
The Bosch numbers on the white internal section for the 88 pin DME plug are 1 928 401 587 and 1 928 403 122. That part has two numbers on it.
This plug has two different size spade connectors. The small spade connector is Bosch number 1 284 477 219(JPT AMP substitute 927 774-3). The large connector is part number 1 284 477 121(JPT AMP sub. 927 775-3). Thank you for your help guys, it was very much appreciated.
Still need to know where to buy this stuff in US ??
Thanks, Bob
Reebuck1 is offline   Reply With Quote
