Old 09-05-2014, 06:43 AM   #3
JFP in PA
ATE Blue is still available, but only for "off road use" as the DOT has now mandated that all brake fluids be clear to pale amber in color.
With a good light on the clear tubing, you should easily be able to see the color change on amber brake fluid.
I would not use any brake fluid that is more than 3 years old and in an un opened car (should have a seal). The fluid can go bad just sitting on a shelf.
