Thread: Oil cooler
Old 09-03-2014, 08:50 AM   #3
JFP in PA
Originally Posted by jsceash View Post
Thanks I've been under the car for the last 3 day trying to see where or if one could be installed. I've pretty much came to the same conclusion. Is there any difference in the 996/997 and the Boxster S. engine mounted heat exchanger cooler.
The original base oil cooler is about 1/2 the size of the "S" engine cooler:
The larger oil cooler is one of the best $200 you can spend as it make a major difference in oil temps as well as life. The larger cooler will just clear the intake manifold on 986's, but not all of the 987's.
