Old 03-29-2006, 08:07 AM   #2
JackG
Originally Posted by coachb
Once you get the back end up should you then do the front one side at a time? This seems like it would kind of twist the front end. Also, from what you have written I should use the center jack point in the back and then insert jack stands then lift the front one side at a time, is this correct? Just want to get this right. I found a nice floor jack with low clearance and am anxious to use it.
When I replaced my CV boots, I jacked the front first, one side at a time, then did the rear in the center. I don't think it matters which end you do first. It does twist the car a bit doing the front one side at a time, but that doesn't hurt anything for the few minutes it's that way. After all, Porsche supplies you a single jack to change your tire on the 986, and it only jacks up one corner at a time, just like every other car ever made.
Jack
2000 Boxster S - gone -
2006 Audi A6 Quattro 3.2
JackG is offline   Reply With Quote
