Old 03-29-2006, 07:48 AM   #1
coachb
a little more detail please
Once you get the back end up should you then do the front one side at a time? This seems like it would kind of twist the front end. Also, from what you have written I should use the center jack point in the back and then insert jack stands then lift the front one side at a time, is this correct? Just want to get this right. I found a nice floor jack with low clearance and am anxious to use it.
coachb is offline   Reply With Quote
