Old 03-29-2006, 06:28 AM   #1
BadBoyS
When Lifting from the back of the car you can put a hydralic jack under the center of the car (check the manual there is a specific point) and then place the jack stands at the rear jacking points in front of the rear wheels. This is very steady. I just did the same thing. The front to me was alittle tricky (if you check threads here some jack at the jack point behind the front tire and then place the stand next to the jack then lower to the stand) I couldn't get this to work well as not enough room with my jack. Although as I raised one side the other side raises too so I put the jack stand on the other side then lower. I do my work then just switch. I haven't read where you can center jack from the front. Hopefully someone wil add as I need to get the front up in the air and safe to change my fuel filter next.... Hope this helps
Badboy S
2000 Porsche Box S arctic silver
2007 Sierra Crew Cab Z71
1995 Honda Civic *Track Toy*
1971 Olds Cutlass Convertible
1968 Camaro SS 396 4 speed
2000 V Star 1100
BadBoyS is offline   Reply With Quote
