Old 08-28-2014, 04:28 AM   #13
opus69
I think the shut off switch is in the transmission. If shutting off before fully closing there could be too much slack in the cabes. If I remember there is some degree of adjustment on cable ends. Thereare also two spring devices on either side of clam shell. If these are weak there may not be enough tension to fully close clamshell. Easiest and cheapest is to shorten cable ends first.
opus69 is offline   Reply With Quote
