Found a post on another forum - someone filled the enclosure with water and it was .14cu after the calculations. That was for the extended enclosure that I posted... the earlier models had a shorter / smaller enclosure which would be even worse...
In the end, not many speakers can perform in that range and produce decent bass or even mid-bass. I will probably use the door as the enclosure with appropriate sound material...
