Old 08-27-2014, 06:31 AM   #3
JudeClayton
Jude Clayton
JudeClayton's Avatar
Re: Car value after tracking?
Hi pal Porsche is a brand name in automobile sector, These cars often needs to change the oil. The problem affects mostly the 2.5 Boxster and Carrera 3.4 engines. When this failure happens, you will see oil and coolant begin to mix together or a slight coolant loss. If you have such problems in oiling system its a serious problem with that engine so you must look for a professional.
JudeClayton is offline   Reply With Quote
