Old 08-25-2014, 06:46 PM   #2
opus69
Sometimes if there is an asymmetry in the sides you may have to adjust the transmissions individually. With the clamshell up you can disconnect the drive cables and adjust them individually with a drill. If is a sticking problem another thing to check are the ball connectors on the batwings. I had one so corroded it caused a drive cable to break. Clamshell spring could also be weak on one side.
opus69 is offline   Reply With Quote
