Old 08-25-2014, 01:18 PM   #9
nor986
Apart that my nozzles are working , that doesn't sound unreasonable... I'll dig in and follow the wires.
Originally Posted by Burg Boxster View Post
nor986 - while in there, you should make sure your front (and rear) drain plugs are clear and battery has vent tube installed... unless you know of another specific reason for the visible corrosion.
Your rebuke is noted. It actually looked pretty bad in there... dug out enough for a small clay pot.
nor986 is offline   Reply With Quote
