Old 08-25-2014, 09:44 AM   #3
JayG
On the slippery slope
JayG's Avatar
welcome. Great color combo (I'm kinda partial as mine is the same) The cars looks very nice
Tons of great info and lots of very helpful people here. Have a question?, do a search first and if you can't find the info you are looking for ASK
Get your tires matched, it will never handle properly with mismatched tires
Lots of threads here on tire recomendations
with minimal service info, I suggest ASAP
Change the oil and cut open the filter
Check all fluids and filters and replace if needed
Brakes require flush and fill every 2 years, so if you dont have a record of it being done, do it. Simple DIY
Check the serpentine belt and replace if if even looks a little bad. It is an easy DIY and takes only a few minutes
Use Porsche approved fluids ONLY
Don't worry about the clutch, they are good until it starts to slip then immediately get it replaced so you don't damage the flywheel
Locate your local PCA chapter and see when the next Performance Driving School or DE event is and take the class. You will be amazed at the performance and capibilities of the car and it will make you a better and safer driver
2004 996 Targa Tip
Instructor - San Diego region
