Old 08-25-2014, 04:16 AM   #4
seningen
seningen's Avatar
Originally Posted by com3dorm3 View Post
I have the same issue after the car is tracked (or AX'd in really hot days).
The problem is that the oil temperature gets too high and causes a significant drop in oil pressure.
For my car (Base 986, running Motul 300v 10W40, EBS oil baffle, Boxster S Oil cooler) the ticking happens when oil temperature hits 230F.
At this temperature or above, the oil pressure @ idle drops bellow 10psi and the tick becomes audible.
Under these circumstances - coming back to the paddock or after finishing an autocross run - I keep the revs above idle where oil pressure is 15psi or above (no ticking)
Of course, this is no real solution.
At this time, I'm hesitant to install a 3rd radiator. I wonder if using 15W50 would help minimize the oil pressure drop when the oil temp hits 230-240F
I've added a temp gauge and oil pressure gauge -- I'll have to keep an eye on
those my next track day.
contemplating adding a fan and external oil cooler.
As I have the S -- I already have 3 coolant radiators.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is online now   Reply With Quote
