If I understand San Rensho correctly it is the fans being on with the AC which cool down the engine. The temp goes back up with fans not running. From what I have read low speed kicks in at 206 degrees and high speed at 215 degrees but the fans always come on with the AC and the temperature drops. If you wanted to have the engine consistently run cooler it would make sense to me to have the fans come on at a lower temperature. At these temperatures the thermostat would be open whether it is high or low temp.
