my problem is solved. Pulled the wheel, and the rotor wasn't turning very easily at all (car in the air on lift bars and in N). Thought maybe a stuck piston in the caliper. Pulled the shoes out and everything was fine - no stuckmopen pistons. As I rotated the rotor, I could hear the squeal. E-brake shoe was hanging up. Pulled the rotor, and the e-brake shoe disintegrated. Caliper is fine. Fix will be pretty simple. Replace e-brake shoes both sides, adjust, add new rear brake shoes WYAIT, and button it back up.
