Old 08-20-2014, 03:40 PM   #14
Topless
Track rat
Topless's Avatar
Yes, you are probably right. I have replaced the sensor but the readings still indicate a cat problem. Marbe I'll try a smoke test on the exhaust to check for leaks. I changed the AOS in the spring and the MAF is fairly new as well. Hopefully it's not really the cat. Major $ !
Maybe pull and compare spark plugs on both banks. If one side is heavily carboned, you know there is oil in the combustion chamber.
