Old 08-20-2014, 09:02 AM   #1
nicecar
havent cracked it open yet due too an engine repair but.... i do know that my bracket is broke not allowing me to slide light in without holding the bracket from the rear thru the wheel well. The light always needs to be tighened from the frunk. sometimes I have had to play with it to get it to lock and even then it was not tight. it never slides out though. From listening to you my 2 problems may not be due to the broken bracket? Did you try the socket suggestion? I will dig around and see what up and pm you when complete. I have a new used bracket for mine I will compare the 2 and look for wear around the locking portion see if this may be our problem.
nicecar is offline   Reply With Quote
