Old 08-19-2014, 04:13 PM   #4
Steve Tinker
Steve Tinker's Avatar
Could be any of the mentioned above, the water pump, AOS or alternatively a loose spark plug.
Try removing the oil filler cap while the engine is running - if its difficult to remove (ie a strong vacuum), the chances are your AOS has gone.
It would be a good time to check for error codes if you have a scanner....
2001 MV Agusta F4.
