Originally Posted by BadBoyS
Sorry Should have given more detail there are two bleeders at each caliper do I need to do both or just the back.
Hi,
I was not aware that there are two Bleed Valves on each Caliper. Are you certain? It's the first I've heard of it. Is this a Big Brake feature?
If indeed there are two Bleed Valves, then I suspect you need to bleed them both. Hope this helps...
Happy Motoring!... Jim'99
