this topic is in the DIY. here is a quick version.
The condensed wire plan is;
2003-4 Boxster Cruise:
Plug C (Grey) on the Instrument Cluster Pin 17 - Stalk Connector Pin 1
Plug C (Grey) on the Instrument Cluster Pin 4 - Stalk Connector Pin 3
Plug C (Grey) on the Instrument Cluster Pin 1 - Stalk Connector Pin 4
Fuse B7 - Stalk Connector Pin 2
If we are talking about this small black stalk connector plug, if you use a magnifying glass you may be able to see the number 1 and number 4 on the end of the plug in the corners.
C17 to Blue (position #1)
fuse B 7 to Black ( position #2)
C4 to Yellow (position #3)
C1 to Brown/yellow (position # 4)
