Old 08-15-2014, 06:28 PM   #2
Chuck W.
Chuck W.'s Avatar
Came across this on Renntech. Hope it helps.
"Try the relays for the spoiler. They are #3 and #9 in the rear relay box (in the rear trunk on the left-hand side behind the carpet. Both relays are for the spoiler are #996 615 102 00. One is probably for the button and the other is probably for the automatic at speed. Swap them and see if your problem reverses (i.e. spoiler goes up on its' own but does not go up with the button). If it changes the problem, then pick up a new relay and replace the bad one. It's worth a shot before you get into real diagnostics. If that doesn't work, come back and post it and I'll give you some more exstensive diagnostics you can do. EDIT: I found the full chart on the relays. #3 is for spoiler extension and #9 is for spoiler retraction."
1995 Porsche C4 Cab
