Yes, my coolant reservoir tank also cracked from old age. If the tank colour is yellow looking that is a good sign that its worn out. The crack is usually on the outer side that you can not see and will leak when under pressure (car running). I had mine replaced last summer which I saved about $500 by buying it off Ebay and having a local shop install it. Saved over half what the dealer was trying to charge me.
Very common problem, pretty much all cars will need it changed around 75k KMs.
