Originally Posted by epapp
Whats your results from using water wetter? I've always wanted to try that stuff, but that was around the same time I experimented with marvel mystery oil
Water wetter, or what ever brand name you choose, is just a surfactant mix to lower the surface tension of water. If you are using a water/coolant mix, it is unnecessary as the coolant already carries similar capabilities, and not all of the commercial products maybe compatible with Porsche coolants.
