Old 08-14-2014, 11:48 AM   #111
Perfectlap
Perfectlap's Avatar
This guy (apparently a dirt track expert, that none of us here are as some have stated) is reading my mind... line by line.
Originally Posted by runjmc2 View Post
The following posted comment on the above link is consistent with what I saw, makes sense, and is from an experienced source:
"I am not a Tony Stewart fan or hater. I spent more than 9 years as a dirt track speedway official so my observations and comments are formulated from more of a black and white viewpoint rather than as an untrained fan. I saw lots of circumstances like this over the years as an official. Thankfully none of them ended up in tragedy, especially the time a sprint driver hit me, on purpose, while on the track with my line up board. I always adhered to a strict policy of white pants, red shirt even when the track did not require it.
I can tell you to start with that if you watch the beginning of the video close, you will see that Tony's sprint car never touched Kevin's. He made a clean pass. Kevin slightly overreacted to being pinched and did not lift soon enough. The terrible dry track conditions allowed his car to slide up into the wall causing the wreck and caution. These guys can see out of their cars good enough to see across the track out the front. I can not prove this, but a lot of car drivers lift their helmet shields during a caution. Whether he did or not, Tony was far enough away and making a left hand corner that he coulod see the events unfolding out the front of his car. It's a pretty safe bet that he saw Kevin exit his car up in front of him.
There is an aspect of this situation that I am not hearing anyone talking about. If Tony knew he made a clean pass on Kevin yet Kevin still hit the wall, seeing Kevin exit his car the way he did would give Tony a feeling of being falsely accused. I have seen many occasions where a racer expresses his feelings with his throttle pedal. If he yells, no one can hear him, but race car engines are loud and blipping the throttle gets attention. If Tony was feeling falsely accused for the caution, then it would not be out of the ordinary for a racer in his position express his emotion with a blip of his throttle and maybe even to shoot some dirt toward Kevin's location. Where we come into the big conflict here the question of whether or not Tony saw Kevin walking on the track. It appears that Kevin first mistook the white and blue 45 car for Tony's and stepped in front of that car to get the driver's attention. Realizing his mistake, he jumped back slightly and refocused on the next car coming down the track which was Tony's. Clearly, the driver of the 45 could see Kevin and his statement to that fact when relayed to the investigator will not work in Tony's favor. You can see that driver react with his steering wheel, not his throttle, to avoid hitting Kevin. Tony could have done the same. I have watched a lot of drivers with throttle steer setups steer around things with their steering wheel. Tony could have done that. He could have also passed by the scene much lower on the track, down by the tires and at a slower pace.
Kevin grabbed Tony's wing if you watch the video real close. I would expect that Tony's heat of the moment reaction was to "Get Kevin Off My Car" and blipped the throttle not realizing that Kevin at that very moment was getting sucked under Tony's tire. I believe it is a safe assumption that Tony never in any way intended to hurt Kevin, however, Tony's track position, speed and history of displays of anger will not play well in to his case. He still may face charges. God be with you, Tony and Kevin's family, friends and fans. "
BORN: March 2000 - FINLAND
