I had the slow flashing light. Replaced water pump, Thermostat, front engine mount then replaced coolant with fresh coolant. Burped the system then found it was slightly low on coolant once I put a little more in I was fine. Yes very sensitive. I also found my primary engine compartment cooling fan was binding and blowing fuses. got one off ebay and replaced all was well.
99 Porsche Boxster
