Old 08-14-2014, 02:27 AM   #11
peterbrown77
So this does not work ???? , I thought it was the go to lube for the 6 speed gearbox
One thing is for certain: If you go with the Porsche oil, you won't have any issues.
FYI, when I had the aluminum cover off the car, I marked a spot directly under the drain plug (this is for the 6-speed) and used a hole saw to put a 1 1/2" hole through it. Took all of 3 minutes to do. Now I can change the gear oil without removing anything but the two plugs. Going from Mobil 1 back to Porsche oil was a breeze.
2002 Boxster S, Arctic Silver, 18" Turbo Wheels, 6-speed
peterbrown77 is offline   Reply With Quote
