Old 08-11-2014, 09:19 AM   #7
BFeller
Black-box, the button has no effect on the top at this point.
BFeller, With the top and button inoperative, how do I remove the rods to the clamshell?
One way I found was to reach through the passenger compartment. Remove the pushrods with the plastic ends that raise and lower the top, removed the bar holds the 'skirt' below the clamshell - it might allow you to get the top in somewhat of a service mode with the clamshell closed. Then work on those black rods that move the clamshell. I have some pics at home- if I can get them posted tonight it might help. Expect those clamshell rods to be under tension and to make a loud sound when disconnected - if that clamshell is down tight. You have a earlier model top assembly?
