Old 08-08-2014, 08:15 AM   #1
MitchSF
How are you wiring your angel eyes? I want to use an ignition switched 12v source independent of the parking lights. If I have to, I'll run a wire from the fuse block.
Is it possible to order male and female pins to fit the existing connector, since there is space for more contacts? If so, can someone find the part numbers?
I plan on using one relay to control the high beam so that when the low beam is on and the high beam is flashed, the shutter will open. When the low beam is off, the halogen high beam will flash. I've done this before and it works well. Another set of contacts on the relay will shut off the angel eyes when the xenon light is on.
MitchSF is offline   Reply With Quote
