Old 08-07-2014, 03:22 AM   #2
method
The H&R kits (available in Road and Clubsport variants) are actually rather popular over here as a mid-range option.
Although the picture I attached above is not my pair, you're quite right regarding the missing piece. It's the nut/washer on top (997 343 561 90, item no 2 on the diagram linked above). As my top mounts are spotless I don't believe they have ever been installed on a car. I need to get a hold of a couple of those as well.
Just found a picture of a PSS9 installed with the stock top mount:
I guess that means that at least the MODE part would fit my coilovers since they and the PSS9's seem to have the same inner diameter as stock.
method is offline   Reply With Quote
