Old 08-04-2014, 12:29 PM   #23
woodsman
woodsman's Avatar
Originally Posted by flaps10 View Post
Yes, it does but good reminder.
I did have a funny occurrence while waiting for the bubbles to subside. I thought, hey I should probably pump the pedal, because you normally do that when bleeding a hydraulic system.
I stuck a leg in the car and touched the pedal and it went "thump!" and hit the floor. I couldn't pull it up with a few pounds of force, so I shut the bleed screw, depressurized the pump bottle and then I was able to pull the pedal up and start the process again.
A bit of a "note to self" moment.
Oh, you mean you didn't have an assistant pump the pedal and hold it down before you opened the bleed screw?
