Old 08-04-2014, 03:35 AM   #13
mikesz
mikesz's Avatar
My 99 tended to run hotter than I like. A few weeks ago I replaced the thermostat, water pump, and front engine mount. I had the time and do most of the work myself. Car has 80k on it and in a little over a year I have experienced most of the Boxster GREMLINS! So with that said I took the old thermostat and immersed it in boiling water to see if it opened properly. It opened but not all the way and when I let it cool did not close all the way indicating to me it was not working properly. Since doing the work my temp gauge is much more consistent. I also replaced the engine bay fan. it was binding and blowing fuses. Had the same issue with the 2 front coolant fans. I am glad I changed out my thermostat just for piece of mind and the work wasn't all that difficult. You may want to make sure all the coolant fans are working properly also.
99 Porsche Boxster
