Old 07-30-2014, 07:22 AM   #13
Nine8Six
Nine8Six's Avatar
That is the advertisement techniques they use to get 1 (one) on 50 (fifty) cars wrapped. Huge huge huge business
>>>>>>>>>>>>>>>>> bing translation:
Product features:
1, it does not hurt the original paint, any change in body color.
2, saturated colours and distinctive texture, and paint touch-perfect match.
3, complete isolation, protecting the body.
4, block acid rain, UV, grease and other common corrosion damage, paint not aging.
5, sand scratches in the fight, blocking paint wear.
6, increase the intensity and texture paint.
7, convenient maintenance, reducing the number of car wash and wax.
8, while long original paint luster, ensure value.
9, opening with the exception at any time, without resin residues, paint restoration.
10, a foil, according to different color 3-5 benefit.
Second, the product performance:
Bright car color film is a high-performance stable polymeric Calendered soft vinyl with adhesive composition with excellent durability and stability for high performance vinyl products, first by the military industry, the automobile manufacturers as well as various Motorsport events are widely, won the trust and universal. After a lot of research and development to upgrade, bright full vehicle wrap vinyl synthetic properties to improve, showing 12 major impeccable advantages:
1, thin and tough: film thickness significantly reduced (100um before, now 66um), flexibility, greater ductility (heated stretch
Back to normal temperature setting does not shrink), available on the smaller arc performance ideal tortuosity, stick together more durable;
2, endurance: an excellent environment resistance, not yellow, and service life of up to 3 years;
3, durable crystal clear: honor to unique coating, add AR, enduring nature and integrated with the original car, totally cracked paint textures;
4, contact corrosion: be able to fend off most of the oil, greases, fuels, aliphatic solvents, weak acids and weak bases, weak salts, completely cut off from acid rain, sand
Bird droppings, oil and other sustained injuries;
5, abrasion resistance: strength and toughness of hyper-restoring force increased more than 10 times, close in tiny scratches, excellent against General scuffing, scratches and wear;
6, excellent optical filter: refraction, filter harmful rays, blocking glare, and UV damage to the paint, gloss and durability to protect original paint;
7, heat-resistant flame retardant: adaptation to temperature-40 ℃ to + 90 ℃, with inert thermal efficiency with good thermal insulation, fire retardant flame retardant;
8, the entire film is covered: No stitching, no seams, no marks, guarantee the car surface integrity;
9, powerful fit: there is no fold, no bubbles, no crack, not up;
10, maintenance convenient: reduce car wash wax work and costs;
11, without leaving any residue: an easy one, easily revealed, inter alia, not to hurt the paint, without leaving residue, achieve amazing results beyond imagination.
12, Super Green: no paint, body and nature produces no toxic side of pollution.
