Old 07-29-2014, 07:46 PM   #5
bboybox
Follow up on my problem with my window just in case someone else has a similar issue. When I found out the motor costs over $350 new to replace, I decided to pull out the electronic control module from the motor assembly. Ended up just blowing it out and making sure the contacts looked okay. Put it back together and tested the motor again and it worked! So I reinstalled it into the regulator and door and my window is now working fine. :dance:
2001 Boxster S Lapis Blue
bboybox is offline   Reply With Quote
