Thread: IMS Question
Old 07-26-2014, 12:36 PM   #12
DennisAN
DennisAN's Avatar
Originally Posted by Slate 01 View Post
I know I have seen it discussed in some thread previously, but how do you determine if your car is a single row or dual row IMS model. I recall someone talking about serial number or build date or something, can anyone advise me?
Also, what is the easiest way to find the engine number, or where is it located on the engine? I have all the documents from the original purchase and there is no engine numbers listed anywhere.
What YEAR is your car?
The 2000 and 2001 crossover years may have mixed up single row and dual row IMS bearings, and it turns out there is NO WAY to tell via VIN, engine serial number, etc. Sadly if you have one of those years, there is no way to tell FOR CERTAIN which you have. You have to pull the exhaust/tranny/clutch/flywheel and look. Having said that the vast majority of 2000 cars have the dual row IMS bearing.
The engine serial number is pin-stamped on a raised flat spot on the passenger side of the engine.
Base 2000 986, beater 1996 Miata, 2011 Suzuki SX4 AWD
Feline mechanics Condoleezza and Dukie
DennisAN is offline   Reply With Quote
