Thanks for the suggestions on what's wrong.
I separated the window motor from the regulator this AM. It looks like it's the motor assembly. When I hit the up button the gear rotates a few turns then stops. I pressed the down position and the motor rotates pretty long. Then I hit the up again and it just clicks like it was assembled in with the regulator in the door. The regulator looks pretty clean, no shavings or corrosion so I'm pretty sure it's the motor. Also if I put some light resistance on the spline as I hit the up button it also doesn't rotate and clicks. Looks like I have to replace the more expensive part.
2001 Boxster S Lapis Blue
