Old 07-26-2014, 07:57 AM   #27
KevinH1990
KevinH1990's Avatar
Originally Posted by Muzzle of Bees View Post
What hand tool did you use to get the top far right water pump bolt out? Pedro shows he used a hand held 10mm nut driver, Pelican shows pictures using a swivel extension with a ratchet socket. It's the hard one mid section on the water pump where you access the bolt from the engine compartment, not underneath the car.
I bought the swivel extension and used that to take it off. However, the Craftsman socket set I have has two 10mm sockets. Once is 1/4" drive and the other is 3/8". The 1/4" drive socket with the adapter to have it fit the handle turned out to be the perfect length for reaching the top far-right bolt.
