Old 07-25-2014, 09:25 PM   #2
hancock1701
Originally Posted by stateofidleness View Post
Well, while under there looking to replace my CPS (see thread prior to this one), I noticed my CV boot on the transmission side is nearly completely separated. That can't be good right? All I saw was $$$ when i noticed it.. so.. maybe it's not so bad to replace that?
What all does it involve? Haven't checked the other side, but most likely needs replacement too... one thing after another!!!
It depends. If only the boots are torn but the joints haven't lost all the lubrication they need, and they are not worn, I think you only need to replace the boots, which is what I did on mine, a do-able DIY, mostly labor. If the inner (transmission side) joints are bad, they are sold separately and not very expensive. If you need to replace the outer joints, I think those are only available as whole half axles ($$$).
hancock1701 is offline   Reply With Quote
