Old 07-25-2014, 06:12 PM   #5
davemon
Originally Posted by Alan Manessy View Post
Wanted to say thanks for the tip on the availability of the Voltage Regulator. Saved me a bundle on my 01 Boxster. The VW dealership had a little trouble cross-referencing the Bosch number so here is the VW number for anyone who needs it. VO38-903-803-EX. Cost me $98 in Toronto. Also regarding the removal of the alternator which can be tedious, make sure you free up the bushing at the back of the upper bolt. You will have to get to it with wd40 and wait. It needs to be backed off to give the required clearance to rotate the alternator to clear the bottom mounting. If you do that, the re and re is quite easy.
Alan
Thanks for the tip!
My alternator is acting up. The light comes on and off. I changed the old-looking serpentine belt but that didn't change anything. Now to tinker with the alternator.
'04 986 Aero - Seal Metallic Gray
Fabspeed: Maxflo Mufflers, Headers with sportcats, Tips; Alpine & Infinity sound
davemon is offline   Reply With Quote
