Old 07-25-2014, 07:58 AM   #35
Brad Roberts
Brad Roberts's Avatar
The engine is STILL putting off the same amount of heat as with a 180 tstat so steady state will inevitably be the same, but with the 160 tstat it will take longer to see the steady state, and depending on the drive/weather, you may no longer get to steady state of ~195 on the freeway and 204ish while sitting still.
You'd be amazed at the number of people who "don't get it" LOL You'd think they owned/drove air cooled cars their whole life
The coolant capacity went up on the 3.2 cars only. They have MUCH bigger water lines than the 2.5 and 2.7 cars, plus the 3rd radiator.
Technically, as displacement goes up on these blocks, there is actually LESS coolant in the block (the cylinder bore gets bigger) The 2.5 and 2.7 share the same bore size
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
