Old 07-24-2014, 07:59 AM   #10
Muzzle of Bees
Originally Posted by aneal000 View Post
Gearing up to tackle this project Friday night. 1998 with 84k miles and it started squealing, drove it home, parked it in the garage and it started self draining. I pulled the belt and there was play in the pulley (bearing/bushing shot). I did notice that it looks like the squeal is due to the pulley rubbing a bolt on the engine.
I was bummed that Pelican was out of stock on the composite blade water pump but I found it online at another company and it should be here today. I already have the low temp thermostat. After reading some of these posts I'm curious about what antifreeze to use and the proper way to refill the system. I do not have the vacuum airlift system - can this be done without? How much antifreeze should I have on hand for this project?
Mine puked a bunch of fluid recently also. I had purchased the parts, low temp thermostat and water pump, from Pelican a while back in anticipation of the failure as my water pump was leaking a little already.
I am going to use the Porsche brand of anti-freeze, the dealership near me said that 2 gallons of anti freeze + distilled water should be enough. I am going to tackle the re fill using the method from the Pelican site. From what I have read the procedures should be followed precisely.
Be sure to have an array of 10 mm options. The bolt I reference in my post below is still giving a hard time.
2016 4Runner TEP
Muzzle of Bees is offline   Reply With Quote
