Old 07-23-2014, 11:22 PM   #4
Edreamsz
It exist yes. Found 4 or 5 documented cars on the internet after an extensive research having the very same issues. For some reason, that I don't understand, most of these pcars, if not all, had either engine/DME swaps, rebuilds or had their ECU hacked into at some stage.
Where is the link some may ask, well apparently your guess is as good as mine.
At the minute all I can confirm is that CANBUS HID kit Charles and I offers works with the following:
1) Boxster (986) 2.5/2.7/3.2
2) 911 (996) all models
^ of course, only those models running "stock" engines, DME, immobilizers, and TMS.
Nine8Six thanks for the testkit! Funny to see that someone else has exact the same issue. I will test the new Ballast and get back to you. The second step will me using a resistor as Pdwight suggests. Let's see!
Edreamsz is offline   Reply With Quote
