Its going to need to be replaced eventually, so it may not hurt.
Have you had the cluster out to check the bulbs?
If everything but the LCD gauges are out, then it probably isn't a bulb issue.
My first suggestion would be to pull and then re-seat all 3 connectors on the rear of the gauge cluster. It is not uncommon for one or more to not be properly seated and this can cause your problem.
