Old 07-23-2014, 07:11 AM   #1
akwarner
About to purchase my first Porsche
Hello all. I am just about to close the deal on a 2000 Boxster S. I've been trying to educate myself and this forum and other Internet resources have proven invaluable. Thanks for providing it.
I did want to ask for some collective advice and opinions. I've read quite a bit about IMS bearing failures and various other things. The car I am planning to pick up has approximately 58,000 miles on it and looks like it was about to have said failure. It appears to have been caught in time and the following service work was performed on it in mid-June of this year:
VEHICLE TOWED IN - WON'T START.
VEHICLE VERY OILY AROUND THE TRANSMISSION AND ENGINE BELL HOUSING.
VEHICLE STARTS SOMETlMES AND IT SOUNDS OK. CHECK ENGINE LIGHT IS ON.
SCAN VEHlCLE FOR CODES P0107 AMBIENT PRESSURE SENSOR BELOW LIMlT, P0102 MASS AlR FLOW SENSOR BELOW LIMIT, LAGS ON THROTTLE AND HESITATES THEN PICKS UP.
VEHICLE NEEDS MAF SENSOR. REPLACED MAF SENSOR. IGNITION SWITCH lS BAD (ELECTRICAL PORTION) - REPLACE IGNITION SWITCH. CODE B1S1 NEEDS OXYGEN SENSOR – REPLACE OXYGEN SENSOR
REMOVED OIL FILTER AND CUT APART. FOUND SOME PIECES OF IMS BEARING MATERIAL AND A FAIR AMOUNT OF LITTLE PIECES OF BLACK PLASTIC. POSSIBLY FROM SEAL AND OR FROM CHAIN RAMPS. LOTS OF PLASTIC PIECES FROM SPARK PLUG TUBES AND SOME FROM THE T-CHAIN RAMPS AND BEARING MATERIAL FROM THE IMS BEARING. PERFORM LUBE OIL AND FILTER, REPLACE IMS BEARING, CAM CLOSURE CAPS, IMS SEAL ALONG WITH SEALER.
The above incurred labor of about $1450 and the following parts were used:
MAF sensor $226.34
DME / ECU $1095
IGN switch $38.32
5W40 syn oil (9.5 quarts) $74.58
IMS seal $13.43
CAM closure caps (3) $22.44
RMS $15.44
IMS bearing kit (LN Engineering) $690
Sealer $10.50
Oxygen sensor $182
This all totaled just about $3900. I have no real clue what all of the above truly means. I'm not a car nut in terms of working on them but I do enjoy driving them.
From a lot of what I have read, this seems like it took care of some of the biggies (IMS, RMS, MAF).
Can you all think of anything else that my be a cause for concern?
Are there anything other things, not necessarily mechanical, that I should be sure to keep an eye out for?
I took a photo of the sticker under the front trunk hood to get the list of options that originally came with the car. It lists:
XMK Painted Roll Bar in Exterior Color
XRL 18-inch Sport Design Wheels
X46 Tiptronic Selector Lever Aluminum/Leather
X98 Handbrake Lever in Aluminum/Leather
222 Traction Control
224 Automatic Limited Slip Differential
236 18" Alloy Wheels
249 Tiptronic S Transmission
288 Headlight Washers
424 CD Shelf in Center Console
432 Multi-Funtion Steering Wheel, Touch, Feel
446 Wheel Caps with Colored Crest
454 Cruise Control
490 Hi-Fi Sound Package
502 Valmet Production (Findland, Ulusikaupunki Built)
551 Wind Deflector & Storage Shelf over Engine
584 Storage Box above Engine
601 Litronic Xenon Headlights
659 Front Fog Lights (1979)
680 Bose Surround Sound System or Hi-Fi Audio System with Booster (Bose)
693 6-Disc CD/DVD Changer
981 Leather Equipment without Seat Covers
982 Soft-Look Leather Seats in Interior Color
I got the explanations from a huge list on a site called Pedro's Garage.
I hope I was able to read the pretty faded sticker correctly. I don't know why there are two different entries for 18" wheels (XRL and 236). I also thought the CD changer would be in the front trunk but did not see it. I'll be looking for it again when I go back to see the car later this week.
I also recently found out there should be a tool kit of some kind. Wasn't sure where that should be but it looks like it should be with or near the spare tire which I did see in the front trunk.
The car does come with a complete-looking set of owner's manual stuff in a black case. I did download a copy of the users manual in PDF format so I can keep on my iPad as I do with pretty every manual I can find for stuff I own.
The wheels (well one in particular) had a major argument with a curb, or curbs. It is all scratched up and had some major paint flaking off. Any pointers to good wheel refurbishers (I'm on the east coast) or "cheap" sources for a possible replacement? I like the wheel design but I will probably need need center caps all around since the ones on there now seem all faded. Not sure if they can be cleaned up or not.
I know that this is a ton of stuff that I am asking, and I expect that I will be returning with more questions as I learn. I hope that over time I can gain enough knowledge to be able to share back.
Thanks for any and all replies.
A.
akwarner is offline   Reply With Quote
