Old 07-23-2014, 07:03 AM   #624
Nine8Six
Nine8Six's Avatar
Originally Posted by Edreamsz View Post
Update: The retrofit center here in the Netherlands, has a good canbus Ballast, but the cannot be 100% sure that it will cure the problem. The current one you supplied has an AMP connection right?
Start with the kit I'll send you. I'd like to see (and document) if this common HID/Boxster/Oil/Batter light thing is caused by a faulty ballast or, like I suspect, "some cars" simply just don't like HID kits.
Let's try the backup kit I'll send first if that's okay with you. If you are having the same problem then by all means, please visit a professional HID retrofitter and try some of their other canbus ballasts to see if this could cut it for your car.
