Old 07-22-2014, 10:23 PM   #6
Pdwight
Pdwight's Avatar
[QUOTE=Reddy Head;410872]It turns out the PO replaced a hose connected to the reservoir tank and NEVER INSTALLED CLAMPS!
I found this out by doing diagnostic work myself - which was relatively easy... This begs the question "What did the mechanic I took my car to even do?!"
Usually always as little as possible...it is why I learned to 90% of my work myself. I did this by researching, reading and investing a modest sum in tools. If a DIY says the job will take 4 hours you can bet I will take 8. I always clean everything, lube everything that need to be lubed and triple check my work with a checklist that I always prepare before starting the job.
