Old 07-21-2014, 08:16 AM   #1
matt123
Boxster 03 - Low Engine Coolant Level
Hi all,
Was driving along merrily on Saturday when a message flashed up on my dash to check my engine coolant level. The light next to the temp guage was flashing fortunately I was close to home at the temperate never went above the normal temperature.
I waited for the engine to cool before checking the levels and it appears very low, below minimum which leads me to the questions where has it gone as I understand it is supposed to last a lifetime.
As a first step I was going to top the levels with a 50/50 mix of Porsche approved coolant and distilled water and monitor it to see if levels reduced. I bought the car second hand so not sure what levels were like before although it was serviced 6 months ago.
I have read a lot about ensuring you don't mix different colour of coolant. I was slightly confused as mine appears to be a greeny colour when all the coolant i can find online appears to be red. Any idea why this would be the case?
Any advice on the above or anything i should check/try would be appreciated.
cheers,
Matt
matt123 is offline   Reply With Quote
