Lower control arm - coffin shaped???
Trailing arm - the one running longitudinal FR to RR?
I've often read here that anti-roll bar links can cause a rattle...
Time to squeeze under her and wiggle and tug on stuff ? If you do this on a hoist with the suspension at full droop it will skew the results if not completely mask them. Check all mounting bolts with wrenches as well.
