Old 07-20-2014, 08:24 AM   #1
JFP in PA
Originally Posted by pparkc2020 View Post
thanks for the input. But .....I'm still confused. So what should I do?
Check your MAF signal to see if it is correct, test your fuel pressure to see if it is in spec, check your fuel trims on each bank to see if one side has a leaking injector, and test your tank vent valve for correct function.
