New owner with faults : Alarm always on, no central locking, no hood or bonnet open
Hello All, I have been searching loooong and hard for help on this and no one else seems to have the combination of faults I do. I will hopefully get all the info and someone can tell me what I am doing wrong:
Here are my faults:
My remote does not work, I have replaced the battery and the lights all flash fine, but nothing from the car. I have tried battery in upside down, locking the drivers door and pressing button 1 at the same time, key in ignition and out and within 6 seconds pressing button one and nothing.
I have checked the drain holes and they are clear, I have checked my carpet in my US Boxster on both the passenger and driver side and they are bone dry. The Alarm unit is also bone dry.
As soon as I open the car using the driver lock in the door manually and open the door the alarm goes off. No matter what I do it will not shut off. Using the remote or key doesn't work. I managed to disconnect the alarm horn but the car is still flashing all the time. I thought it was the front bonnet that was open at the time causing the fault so stupidly I shut it. now I can't get to the battery because the buttons for the front and rear bonnet and hood dont work either.
the interior central lock switch on the dash does nothing either.
The key will turn the ignition on fine but the car immobilizer is clearly still active and wont allow me to crank....
I just am at a complete loss on this. Its like the alarm system is fully on and wont shut off even with the correct key turning in the door lock.
Any help at all would be great. I will use the emergency pull chord to get at the battery tonight but this is not the best start to my first German car and first Porsche.
Charlie.
