Old 07-19-2014, 12:45 PM   #12
JFP in PA
I want to be able to see the information, when enabling using Durametric it says it us enabled but an error occured. Or the beginning of this thread has the justification for trying to do this research and help others who might be having the same problem.
It sounds like you don't have the system wired up, so it may be throwing the error because the function is active in the DME but not connected to the cluster via the stalk or switch, which is also why there is not display. Like I said, it is either on or off, there is no middle ground.
